It is currently Fri Jul 25, 2025 6:36 am
PostPosted: Tue Dec 27, 2022 12:24 pm
Last Name: Bradley
Country: United Kingdom
Does anyone know whether these can be trimmed to length, like the older type with the visible segments under the black shrink wrap. I think this is a Fishman but there are numerous similar ones available at a fraction of the cost. Mike
PostPosted: Tue Dec 27, 2022 2:17 pm
I it's a fishman Martix, I doubt it - "Due to the nature of the manufacturing process, the Acoustic Matrix pickup cannot be cut to fit once it is made."
https://www.fishman.com/FAQ/can-the-matrix-pickup-element-be-cut-to-fit-any-length-slot/#:~:text=Due%20to%20the%20nature%20of,fit%20once%20it%20is%20made.
PostPosted: Tue Dec 27, 2022 2:18 pm
I wouldn't these are uber fragile.
The Fishmans have a strip of thin copper with six crystals specific to an individual requirements string spacing. The crystals are what vibrates and if you upset the wrapper at all it changes the pressure of the wrap on some of the crystals and degrades the performance and balance of the element. You can kill one completely by trimming it too or you might get away with it but I would not do it especially if it belongs to someone else.
What are you trying to do if I knew that maybe I could be more helpful with what you really want and that is how to proceed not be stopped in your tracks?
But these are VERy fragile so be careful.
PostPosted: Tue Dec 27, 2022 2:19 pm
Colin and I posted at the same time but it is the same message, cut at your own great risk.
PostPosted: Tue Dec 27, 2022 2:45 pm
Last Name: Bradley
Colin and Hesh, thanks for you replies. I've seen it written by Fishman that it can't be cut, and that may be the case but I'm a little suspicious , after all they will sell more if nobody cut them. Having said that, I wouldn't try and cut a Fishman bearing in mind what they cost, but I was thinking more about the cheaper alternatives that can be seen for just a few dollars(£s), and wondered whether anybody else had tried.
Hesh, what I'm trying to do is fit one to a ukulele, but the ones I've seen for sale are either too short(40mm) or too long (65mm) . Ideally 50mm ish would be better to fit my 42mm string spacing. Thanks Mike
These users thanked the author mikeyb2 for the post: Hesh (Wed Dec 28, 2022 2:33 am)
PostPosted: Wed Dec 28, 2022 2:37 am
Thank Mike for the details.
PostPosted: Wed Dec 28, 2022 9:57 am
First name: Pierre
Last Name: Castonguay
City: Québec, Qc
Very fragile indeed, I'm guilty of ruining one of those Fishman Matrix that'd been living in my own J200 by simply scratching the surface while trying to get it out. Solid bone replaced it, and I'll install something else when I have some free time to work on my own guitars. It sounded so bad to my ears I was almost glad I scratched it so I'll never be tempted to use it elsewhere.
Pierre
Guitares Torvisse
Pierre Castonguay
These users thanked the author Smylight for the post (total 2): Hesh (Wed Dec 28, 2022 12:03 pm) • mikeyb2 (Wed Dec 28, 2022 10:20 am)
PostPosted: Thu Dec 29, 2022 12:07 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
do not cut. drill and angled hole at end of slot to take up excess length. of course this assumes bridge is wide enough
PostPosted: Thu Dec 29, 2022 12:33 pm
Last Name: Bradley
Thanks, if I understand you correctly, are you suggesting they can be bent downwards to hide the excess?
PostPosted: Thu Dec 29, 2022 1:11 pm
Mike may be thinking of the LR Baggs flexible UST (under saddles transducers). These, the Fishmans should not be bent it it may change the relationship of the two copper strips and the crystals.
Uke pick-ups are often problematic and can work very poorly in our experience. If it's an UST the downward pressure on the saddle for a UKE may not be sufficient and many not be uniformly sufficient for all strings. We see this from time to time when asked to improve the balance on these.
There is one brand of Uke that people give for Christmas presents and right after Christmas our phone is ringing with poor balance issues and there is often very little that can be done with a UST other than making sure everything moves freely (saddle).
I'm not up on what's out there for Ukes but a mic may be a better bet.
These users thanked the author Hesh for the post: Smylight (Thu Dec 29, 2022 9:10 pm)
PostPosted: Thu Dec 29, 2022 3:48 pm
Last Name: Bradley
That would make more sense, and I do have one of the flexible braided types but it is thicker than I would like. The reason I'm looking at these red piezos is because they are thin and more suitable for a small bridge for a ukulele. I am building a Martin style 1 type soprano as a surprise gift for someone, who is likely to use it occasionally on stage so I'm not in a position to discuss it with them. I'd like to pre-install a passive UST to get them going, and if they want to upgrade it later on, then so be it. Cheers Mike
PostPosted: Thu Dec 29, 2022 10:13 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
Well, if I am doing something wrong, I want to know. The slot template I use is about 1/8" shy of element length, so I have always done this with no ill effects. But when I do that angle drill at end, I rotate it a bit to enlarge the hole. I have never given this much thought and it now seems reasonable for me to lengthen my slot. No element I have ever removed from one of my installs has ever been bent. So, ignore my advice. I learned a lot here today. Thank you. (but don't cut the element).
It would be nice if Fishman mentioned this somewhere. Does anyone have a link? I learned this technique here a while ago.
These users thanked the author Mike OMelia for the post: Hesh (Fri Dec 30, 2022 2:31 am)
PostPosted: Fri Dec 30, 2022 2:34 am
Mike it's actually working for you so maybe it's OK to do what you have been doing and thanks for the details too. Enlarging the hole may prevent any bending being necessary and that makes it work. And that's what maters making it work.
Yeah Ukes and pick-ups are often problematic especially because the cheap ones on the market have crap electronics that basically function but often not very well.
These users thanked the author Hesh for the post: Mike OMelia (Sat Dec 31, 2022 10:08 am)
PostPosted: Fri Dec 30, 2022 1:28 pm
Last Name: Bradley
Please bear in mind Hesh and Mike, that I'm talking about a soprano uke bridge, open ended 62mm long, unlike a closed pocket guitar bridge. I appreciate the advice though and will file it away in my memory, for future reference. Many thanks Mike.
These users thanked the author mikeyb2 for the post (total 2): Mike OMelia (Sat Dec 31, 2022 10:08 am) • Hesh (Sat Dec 31, 2022 2:29 am)
PostPosted: Sat Dec 31, 2022 2:32 am
Yep no tucking with an "thru style" saddles as we call them here in the states. What we do with this Mike is we have a saddle mill, the Collins saddle mill and we mill a special pocket in the bottom of the saddle slot for the UST and then it lives there. We mill it to a depth few tho shallower than the UST is so the saddle is riding on the UST and the UST is in a pocket.
It's a very neat approach and works great too but your UST has to be shorter than your saddle slot and even your bridge ;) for it to work.
PostPosted: Sat Dec 31, 2022 6:15 am
Last Name: Bradley
Thanks again Hesh for the explanation. This is exactly what I will endeavour to do, but using a Dremel(and homemade jig of some sort) to rout the pocket. Looks like I'll have to buy a 50mm piezo, but they are slightly thicker at 1.7mm, thus requiring a deeper pocket. Cheers Mike.
These users thanked the author mikeyb2 for the post: Hesh (Sat Dec 31, 2022 12:36 pm)
PostPosted: Sat Dec 31, 2022 10:21 am
Last Name: O'Melia
City: Huntsville
State: Alabama
Now that I understand better, check out K & K pickups. They have better solutions for this. U can get a UBT jack, or one that sticks to top (external) with a side mount jack (non-invasive).
These users thanked the author Mike OMelia for the post: Hesh (Mon Jan 02, 2023 2:40 am)
PostPosted: Wed Jan 04, 2023 4:44 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
OK, so I spent some time speaking with Gary at Fishman. When he finally understood what I was doing he said there is no issue with that. As long as one does not bend the transducer (matrix). This particular transducer is not made of 6 crystals, so string centering is not an issue (the AG series is a different story). You also do not want to cut the matrix transducer. So yes, you can bury excess length as long as the hole does not put pressure on the matrix transducer.
This is a long way from the OP's original intent, but these points were made above, so good place to address them.
These users thanked the author Mike OMelia for the post (total 2): Hesh (Thu Jan 05, 2023 3:14 am) • mikeyb2 (Wed Jan 04, 2023 5:21 pm)
PostPosted: Thu Jan 05, 2023 3:15 am
Good stuff Mike and thanks for taking the time and effort to get the scoop from Fishman, very much appreciated.
PostPosted: Thu Jan 05, 2023 6:32 am
I have used the uke K&K pick up
I much rather them then under saddle piezos
https://www.amazon.com/s?k=k%26k+aloha+ ... 2y4yee2e_e
PostPosted: Thu Jan 05, 2023 1:20 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
https://www.amazon.com/Aloha-Twin-Doubl ... 13d670b6bc
and
http://www.tapastring.com/vintagejack.htm
This is what I will be using. Tapastring uses a standard mandoline/uke end pin sized jack. 1/8" out. They sell a 1/8" to 1/4" adaptor cable
PostPosted: Sun Jan 08, 2023 7:23 am
Last Name: Bradley
So now I'm looking into Mike and John's suggestion of a K and K type pick up. It won't be a K and K but the cheaper alternatives made from a couple of piezo discs wired to an endpin jack. Now this raises the question of where to place them. I know they would normally be glued to the bridge plate directly under the saddle, but that might be difficult as my bridge plate is rounded over(as per the Grellier plans), so I was wondering whether it would be ok to place them just in front of the bridge plate? I have used these discs before on a cgb a few years ago and they do work, it's just a matter of placement.
Any ideas would be appreciated, thanks. Mike
PostPosted: Sun Jan 08, 2023 10:51 am
Get some thin double stick tape and try them out as a temp check in various locations and see what results. K & K offers the tape install option although we never use it and it would not survive many of our clients who are performing musicians where the instruments are at times in harsh environments.
Did you see the post and video that Terry Kennedy posted I believe in another active thread using a clamp to locate and install the discs? that would a great way in a Uke too.
EDIT: Here is Terry's link. https://youtu.be/ItaMGL8Ktkc
PostPosted: Sun Jan 08, 2023 12:24 pm
Last Name: Bradley
Thanks Hesh, good idea and yes, I did see the video which is one of the things which swayed me towards this type of pup, I certainly can't get my hand down a soprano soundhole!!
Thanks for posting the link anyway. Cheers Mike.
These users thanked the author mikeyb2 for the post: Hesh (Sun Jan 08, 2023 1:16 pm)
Users browsing this forum: rbuddy and 20 guests
